scubasteve
I have the pushrod cover off my M and I'm wondering what to do about a pair of pan head screws I have found threaded into the block. When I removed the cover the bolt hole in question had a 1/4-20 UNC pushed into the hole. The threads for the hole are 5/16-18 UNC. When the cover is installed the bolts can't come out of the hole but I don't know what the hole is for. I am assuming it is a cross drilled hole for an oil passage. Should I thread a 5/16-18 UNC pan head screw in place of the 1/4 - 20 UNC? I can't imagine I want oil pressure dropping from oil leaking into the pushrod covers? What do you have screwed in yours is my question?
