Trent Couch
I?m finally getting around to installing the live pump on my M I
just acquired a Christmas tree valve and had a couple
question on the routing of the hydraulic lines. I will post a
couple pictures to hopefully be as clear as possible. My belly
pump is gutted and I?m in the process of plugging all the holes
so the belly pump will be used as a reservoir only. Since doing
that will it be necessary to install a pressure relief valve where
I have marked in my picture? And if so can I tee off of it and
go to the opening that?s up higher on the belly pump rather
than putting it at the bottom near the suction line? The tractor
pictured is not mine just a visual of the T at the suction I?m
referring too. And the suction line goes to larger port on the
left on the live pump?
I appreciate any assistance I?m finally trying to wrap this M up
