Hi All. I am needing some advice on the front of my gas farmall 706. Forgive me if I get some terminology wrong. So for the last two years I have been trying to keep
2 bolts tight( the one in the center of picture one). I came to find out this winter that there actually 4 bolts. I have been tightening the two closer to the oil pan.
I noticed there are two more at the front and they are all the way out and just sitting there. Because of the way my bolster and axle are situated they cannot fall out
to the ground but can't be tightened without taking off the whole front axle and the cast iron plate above it.
While I was discovering all this I noticed a little ouch in one of the bolster bolt holes.(see pic two). Here is where I need the advice. Can I just leave this as
is with the other three bolts holding it? I do minimal work with this tractor(mostly for acreage stuff). If I should replace this piece, how much is the part and how
hard to take out? Thanks for any advice.
Mike
Mike
