Company Logo Shop Now
plowing with a 140
badger bob
03-31-2020 10:34:06
I have a 1965 ih 140 and 2 plows witch one to use ? the 2- 12 plow or the !-18 plow ? thanks Guys Bob
badger bob
04-03-2020 09:00:19
 Re: plowing with a 140 in reply to badger bob, 03-31-2020 10:34:06
thanks guys for the help, plow are at my house and the farm is 3 miles away but ill try the 2-12 and see how it work. thanks
Jal-sd
03-31-2020 16:47:15
Depends on your soul type, if it's been worked recently, how deep you plan to set the plow, what shape the plow is in etc. The area of resistance for the 2 bottom is 24", while the area for the 1 bottom is 18". A 140 has an upgraded A or B engine, 3rd generation, so you should plenty of power regardless of your soil condition. I'd try them both if you have room & time. Then use the one that does the best job.
d7fever
03-31-2020 12:09:36
I've got a Farmall 100, I've got a fast hitch 14 inch 2 bottom plow and a fast hitch 16 inch flip flop single bottom. I've pulled both . Tractor has no problem pulling the 2 bottom . You should use the one that gives you the best job.
ih560
03-31-2020 12:06:29
I plow every year with a Super A and one bottom of the 189A plow. It does a great job. Typically it plows fine in 3rd gear, but the engine is getting due for an overhaul and it was a little stickier this year when I plowed, so I plowed in 2nd gear.
FastFarmall
03-31-2020 11:45:19
My brother has a 50 C,he had a mounted 2-14 it was plenty for it!
henryv11
03-31-2020 18:25:07
 Re: plowing with a 140 in reply to FastFarmall, 03-31-2020 11:45:19
My 1928 10-20 pulls 2 X 14,s in 2nd gear most all the time.
FastFarmall
03-31-2020 20:45:37
 Re: plowing with a 140 in reply to henryv11, 03-31-2020 18:25:07
well after the novelty wore off, he sold the plow it was a big load for it, he decided it made a better raking tractor!
Farmall plowboy
03-31-2020 10:45:14
Never plowed with a 140, never even drove one,but I've plowed with an A with a single 16" and that is all it wanted. Never seen a single 18", my guess is you'd get a better job out of the single bottom.
Today's Featured Article - ... [Read Article]
Latest Ad: I NEED A PC160 FOR JOHN DEERE 100 DISC LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
Binary file (standard input) matches
