LS Motor Oil
Sister has little blue LS tractor, wants me to service. Manual doesn't spec diesel motor oil like Rotella, do newer little diesels not need it?
Thanks
You might want to consider Rotella 10w-30 but still a diesel oil. Also, does it have an emissions system, the newer engines require the appropriate spec of oil.
(quoted from post at 18:12:54 03/30/20) You might want to consider Rotella 10w-30 but still a diesel oil. Also, does it have an emissions system, the newer engines require the appropriate spec of oil.
No real idea what an "LS" is but my first question would be what oil does the manufacture recommend, not what make oil cause they might sell oil with their name on the bottle and I highly dobut they actually refine their own oil. But waht specs. do they suggest? 15W-40 10W-30 5w-30? along with any other specs!
