Married2Allis
I am looking at a 1968 544 hydro gas utility with about 4000 hrs. Are there any potential problems with the hydro unit that I could tell from operating it or things I should notice? -thanks, Bret
When it is working it is great. When it fails you might as well junk the tractor if you have to send it out for repair $$$$$.
They also like gas. IMO
Checking hydro
With the tractor in low range, step on the foot-n-inch pedal (where the clutch would be if it was a gear drive), move the hydro lever into the blue area of quadrant, half throttle or so, hold the brakes, and let out the f-n-I pedal. A good hydro will overpower the brakes. In high range, same procedure, it should stall the engine. If the hydro starts whining instead of moving, the hydro has a problem.
If you want the straight scoop on the IH hydro transmissions in tractors, call HERR'S Machine, Google the
phone number. They are the #1 hydro repair shop for them. The topic comes up occasionally on the Red
Power site, never heard a bad comment, but lots and lots good ones!
