Company Logo Shop Now
IHC carb fuel inlet
rc_cola85
03-24-2020 15:10:25
I have a 49 cub with the original IH carburetor. Since getting the tractor home and fixing a few of the ailments, I have found that the fuel inlet threads are pretty much stripped. Is there a way to repair the threads and keep it the original NPT size? I'm unaware if helicoils are made in that size or if there is enough meat there to put one in without destroying the housing.
560Dennis
03-28-2020 16:59:34
 Re: IHC carb fuel inlet in reply to rc_cola85, 03-24-2020 15:10:25
I’ve brazed it to fill in the strip section . Mill with end mill to true , don’t drill will walk of center and the retap with 1/8 npt tap
rc_cola85
03-26-2020 17:17:20
I actually have one of those carbs ordered in case I have to swap the top. If nothing else, I can swipe the jewelry off it. The floats are plastic as I understand. Jets are probably all the wrong size since they don't use Freedom Units over there.
c.amick
03-25-2020 18:22:45
I wonder if the top housing of this carburetor would fit yours, see link. It's probably not a very good carburetor.
The tractor vet
03-25-2020 09:40:46
Yep like Jim said and posted i personally have used this product on a H carb as around here i do a lot of carb work since i am and old Fart and have been working on cabs now for darn near 60 years. There is no rethreading , drilling . You do need to start with a clean carb and clean fitting. though . Once i run them thru my carb cleaning stuff they are clean as new and you follow the instructions to the letter and you can remove and reinstall one kit will do more then one carb .as it is like the old Brillcream a little dab will do ya and use the thread unlocker on the inlet fitting .
Janicholson
03-24-2020 15:26:12
This works well. I would just barely remove material from the face of the threads to allow th fitting to get 1/16" farther in the hole, then use this product as directed. Worked well for me. Jim
Russ from MN
03-25-2020 10:44:17
 Re: IHC carb fuel inlet in reply to Janicholson, 03-24-2020 15:26:12
Is JB weld E-10 resistant? I could see removing the screen and gluing the fitting in.
rc_cola85
03-24-2020 16:00:48
A little steep on the price, but I found it a little cheaper on the web. I'll give it a shot and see what happens.
Today's Featured Article - Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h ... [Read Article]
Latest Ad: John Deere 50 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
