560 hydraulic pump
shot560
Im having an issue with my tel a depth control. Until I have time to replace the valve I am going to remove the hydraulic pump so I can still use the tractor. I understand I will not have any power steering or hydraulics. The question is will it cause any damage or problems not having the pump in the tractor. Thanks
Yeah, I know you said you know you won't have any power steering or hydraulics, but did you realize the tractor will be practically undriveable without power steering? It won't be like driving a manual steering tractor. It will be like driving a manual steering tractor with three tons of extra weight on the front end.
Yes thanks. I plan on changing it over to the standard valve. Now I just need the time and the money.
We need to be careful on this forum to keep posters safe. We have no idea what you know or don't know. So Barnyard's info was normal best response. Jim
I just thought of the perfect solution. Buy another tractor even if it's just an M to get by. Then you can take your time to fix the 560 properly with the parts you have without sticking much in it. Resell M later if nesessary.
