farmer656
Man called me today said his 3 point wont go down,, just had a new pump installed, and filter,when I get there they have the linkage on draft control un hooked, froze in cab,, they had the three point center link bracket off on rear of tractor, they started tractor and hyd fluid started running down from valve body,, where do I start ?
It is likely that the draft control internal linkage is out of place. There is a long strip of linkage to the right of the top link hole inside. there is a follower that must be hooked on it, and is known to be a rascal. It is easy to put back in place, Don't do it running!! Jim
Well first ya need to know if it is and open center system or the PFC system . and free up everything that is froze up . Then ya need to have a BOOK .
