Have an issue with the main clutch on both 350U and 504U.
Doesn't seem to have enough pedal travel. Next to no free pedal and the clutch will release only at the very bottom of travel.
If clutch free travel is adjusted to the prescribed 7/8" to 1-1/4", the clutch will not release.
When the pedal is up, there is about 3/4" between the clutch pedal arm and the foot rest. The pedal up stop is at the brake housing.
I could maybe get about another 3/4" of pedal travel if I were to heat and bend the pedal arm. But, really don't want to do that.
Does the long pedal arm bend over time?
I don't know of any adjustment when it's an issue of pedal travel.
Has anyone experienced this and found a solution?
K-Mo
K-Mo
