Ellis Kinney
The coil for a Super MTA is a little shorter than a standard coil and also has the distributor wires hooking to one end and the coil wire to the other. In
addition to that it is a little shorter. I need one in 12 volt. Is there such an animal? Right now I have a standard 12 volt coil setting up on spacers to
get it to fit. What causes the problem is the addition of the hydraulic pump at the distributor. Ellis-
