I am currently working on resurrecting a 400 farmall.. it had sat in shed for a few years before I purchased.. I cant get to start.. I can get smoke mostly white but a little black and sounds like it wants to run with starter turning but doesnt.... and manifold does get warm... I have cleaned the carb but not sure I have set right . Put in fresh fuel, new starter, new plugs, points, distributer cap, coil.. questions... I am on a 12 v system and coil says 6 v without external resister.. so I dont know if it is correct.. other question involves timing.. so I set top of center as in my operator manual and then I try and start a few times and checked again but now distributer pointer at 3rd spot instead of 1st spot... ( so directly opposite to where it should be
. I have also put new belts on... any help would be appreciated before I have to call my mechanic buddy and look silly... thanks in advance..
