drforsythe
New User
Hello, I m a first timer here so please bear with me.
I have 1970?? Farmall Super A that s beginning to have a possible gear box issue.
When I m scraping our road in 3rd gear the tractor seems to be starting to be getting into a bind and starts slowing down to the point that the tractor will stall if I don t press in the clutch.
When this stalling begins in can shift to 2nd and continue.
There is not enough gravel or dirt in the blade to cause this stalling.
I m thinking that there is a bearing or bushing that is causing this problem. I ve had this issue for a couple of years but now it s gotten to the point that it s getting hard to use.
Replaced the clutch winter of 2018/19 and replaced the bushing in the crank end for the clutch shaft. Just replaced the right side tire and brake band and checked the bearing for that side and bearing is good. All the gear oils are good.
Anyone have any insight on this problem or do I bite the bullet and plan on replacing all bearings, bushings and seals for the gear box and left wheel.
Thanks
Donnie [/b]
Thanks
Donnie [/b]
