Company Logo Shop Now
TractorLinks.com
Re: Need some technical information
D Slater
02-20-2020 13:13:12
Best way on those old tractors unless something is off excessive is to have the top off and measure the backlash of ring gear with a dial indicator to set back the same. There was enough left of your carrier housing to snug it back up and check. With how you are doing it you just as well use the original shims and hope the housings were machined the same. After you tighten it up reach up through pto hole and and make sure backlash is not to tight or way loose. Most used sets checked now have backlash over spec and run the best when kept the same. Thinking around .009 to .012 was in spec but would need to look it up to check my memory. Another option is to measure depth from pinion housing face to differential bearing machined face inside the pinion housing and compare old housing to replacement. If you have the stuff to measure and using the original differential bearing you can figure shims to go back like before.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
