My brothers 656 is sitting forlornly in a back field because of an injector pump that failed. The pump shaft is snapped off about 4 inches from the timing gear in the motor. The task is to get the broken shaft out of the gear and replace the pump. Supposedly , you can loosen the nut on the end of the shaft and drive it backward with a drift and it should pop loose. Tried heat , penetrating oil and increasing violence but no joy. There really isn't a good angle to get to the end of the broken shaft.
Told bro to put down the tools and let me see if any of the people on this site have had any experience with that problem. Looks to me like he'll have to take off the front of the engine to be able to take the gear out and put it in a press, but it doesn't seem like it should be that drastic a fix. Any thoughts?
Re: Removing a broken injector pump shaft on a 656 in reply to Hartlyboy, 02-18-2020 15:31:27
Dieseltech, you were correct. The key had sheared and it took a bigger hammer and drift to punch it out. Now we have to be sure when we put the new pump in that we have the timing marks lined up. That timing issue has proven to be more difficult than we thought it would be, but at least we have the old shaft out.
had one do that on a 2640deere i had had that pump off about 20 years back i end up taking off the front cover and putting the gear in a press to get the broken shaft out it had sheared the key and wedged it into the gear of course to do the front cover the front end fuel tank radiator hyd pump turned in to a lot more job then it should of been
Could be the tapered shaft has also sheared the key. Just get a bigger hammer and drive out the old shaft. I'd also have the pump hydraulic head pressed apart to find WHY pump seized. If the cause is not found it MIGHT happen again.
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
