brake bearing cage oil seals
The new oil seals from a company (even NAPA) will be thinner from front to back. This is good because it allows the lip to touch the shaft in a new place. Putting 2 of them in the opening is often done, and reasonable. If you do, put wheel bearing or grease gun grease between the two to be sure the outer seal has lubricant. The old seal will be used to size the new ones, or the IH part number. jim
