Farmall Super M power steering
Vince Visaya
New User
Help.....I bought a Behlin power steering unit and installed it on my Super M. I connected the hyd lines to the existing lines going to the remote outlets. Now when I run the tractor the 3 point does not work and there is no pressure in the system. Its as tho the fluid is running directly thru all the system and there is no pressure.....what did I do wrong??
Pressure is simply bypassing somewhere.The oil will follow the path of least resistance. You need a diverter valve for everything to work.
Need more info. Does it have a valve for up and down pressure? Just a belly pump or a engine pump? If hooking lines to 1/2 inch
pipe ports on belly pump or unit under tank if equipped is the return line from power steering unit plumbed into fill opening of
unit used? If it has a valve for up and down pressure, are the two lines from it going to 3 point hitch?
Well if it has live Hyd. then ya need a FLOW divider to split the flow as what you want going to the P/S is 3 gallon per Min. or as we call it GPM and the rest to the hitch and remotes . What we all need is PICTURES because we are not therte holding your hand . On a live system you split the main line coming off the pump and install a flow divider between the pump and the lift all , You can get one from any hyd supplier or ya can use the one that they used on F 504's
(quoted from post at 18:11:39 02/17/20) Well if it has live Hyd. then ya need a FLOW divider to split the flow as what you want going to the P/S is 3 gallon per Min. or as we call it GPM and the rest to the hitch and remotes . What we all need is PICTURES because we are not therte holding your hand . On a live system you split the main line coming off the pump and install a flow divider between the pump and the lift all , You can get one from any hyd supplier or ya can use the one that they used on F 504's
Thanks so much for the info....I appreciate the help I get on here from alot of folks
