urbancase
well after a year and a half working on the paint and in frame rebuild I got it running, had a hard time getting the injection pump primed. I have a few questions maybe you guys have dealt with.
1. the IPTO does not completely shut off and turns when the leave is down, you can stop it with a channel locks. I have had a few of them out over the year's to have them rebuilt and I have replaced the small pin also a few time on the engagement rod but never ran in to this. what is this a sign of or does it need rebuilt?
2. oil pressure is at 38 psi when warm and 41 psi when cold, I rebuilt the oil pump when I did the in frame does that sound right?
3. hard starting when cold I had the head redone with new vales and I know I have the per combustion cups in the injectors in the 6 o'clock position. I did not have the injection pump off or changed any timing. this is a early 282 with the slip fit sleeves and the glow plugs are working. is this normal for this motor? when I got this tractor it had been eithered to death as that is how they started it.
4. my first tractor I had was a 706 with the 310 motor and it had a block heater can I put a block heater in this motor? this tractor main job when done will be pulling hay wagon's and running grain auger in the fall. I still have a lot to do yet as I need to fix some wiring and I do not have any of the white paint work done yet.
thanks in advance for your guys help.
