Picked up a 1938 F-20 that someone added a starting gear to directly behind the fan belt - the belt is a little
frayed (not the original leather) from slight contact with the gear over the years. There is no starter now, just
a flat 12 inch diameter (approximately) solid 1/4 inch thick gear with teeth on the outside of course. No obvious
sign of where it was mounted - probably underneath somewhere, not to concerned about it - but I would assume
someone had fabricated this. Iv'e seen them mounted elsewhere but has anyone saw this version/placement of
"homemade" electric start?
