SadFarmall
My 1937 F12 had severely worn rocker arm bushes and rocker shafts. I have had them re-bushed and purchased new shafts. All good to go again. The question, which comes to my mind is about lubrication of the rockers. When I dismantled the motor, the felt valve oiler pad was completely soaked with carbon, kerosene and some old oil and had become effectively impervious to oil seeping through. I know that 1020 tractors, Farmall Regular and others had two oil caps on the rocker cover, which the F12 lacks. Is it worth fitting them or perhaps two sight feed lubricators or should I just not worry about it?
SadFarmall
SadFarmall
