I have a Farmall 460 that I'm having some trouble with. When I fill the rear end with hi Tran to the check plug the oil still seems low. When I pull the filter housing off his only about half full. I see the hole in the casting that goes back to the rear end where the filter would get its oil from. When the rear end is filled with 10 gallons as calls for, the oil is not even running into the filter housing. This is giving me cavitation in the pump. Added three more gallons and it's barely trickling in ,so the pump is still cavitating. My question is doesn't the pickup tube hole for the pump behind the filter have to be completely underoil??
