IH Steering Wheels
Ultradog MN
Location
Twin Cities
I'm working on a Ford 4200.
My steering wheel is real bad, plastic all busted away, etc and NO One has a replacement for it.
This steering wheel is dished much deeper than the all purpose 4000/5000s.
My dish is about 5 1/2" from the bottom of the hub to the top of the wheel.
Was there an IH model with a deep dish like that?
My splined steering shaft is 3/4" but I have access to lathes, mills and the like and can modify either my splined shaft or a different hub to fit so am not too worried about it fitting on the hub.
What models of IH or other brand should I look for that they sell a new deep dish steering wheel for?
Not the best photos but they give you some idea.
I will post this on the JD board too.
Thanks for any info.
As long as you can/are willing to modify the mounting hole as needed, why limit your search to tractor steering wheels?
Lots of automotive steering wheels from the 60's and 70's were "deep".
For some reason, a 1964 Ford Galaxie steering wheel comes to mind.
I'm not aware of ah IH wheel that is that deep.More important,is the hole. Diameter,splined,or keyed.Several companys offer replacement wheels.
I just saw in the Farm Show paper that the guy that makes the replacement gauges does that. Jerry T???? is his name.
