Company Logo Shop Now
TractorLinks.com
Farmall A clutch housing cover gasket (felt)
jbarnes60@cox.net
02-12-2020 05:10:55
Hey guys I'm starting to reassemble 1944 Farmall A and need to locate gasket that is installed on clutch cover just aft of oil pan on bell housing. The old one appeared to be felt. Cannot find it any of the big tractor parts houses. Any help appreciated.
caterpillar guy
02-13-2020 00:41:32
 Re: Farmall A clutch housing cover gasket (felt) in reply to jbarnes60@cox.net, 02-12-2020 05:10:55
For those kind of things we use old fuel oil furnace filters separate a section then separate one of those about the right thickness then with your fingers in the hole or over a shaft/pin in a vice start working it out to the size of your shaft. I think I did that for a front spindle on our 1466 to keep dirt out of it.
Bob
02-12-2020 07:20:52
If you want to keep it "original", FP Smith shows a felt in stock, #57575D, phone 800-558-7228.
Or, use some foam rubber weatherstripping from a hardware store or building center.
Other choices, you may be able to find thick enough felt at a hobby/craft store to cut your own, or McMaster will have it, for sure. https://www.mcmaster.com/felt
jCarroll
02-12-2020 06:51:37
Why bother with any gasket? You are not gonna have loose oil inside...... nor driving through 3' of water.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
