Company Logo Shop Now
TractorLinks.com
574 Hyd. Lift will not go Down
RTR
02-11-2020 21:39:21
Not sure what is going on here but the lift on an IH 574 tractor will go up as soon as lever is pulled or as soon as engine is started but when I move the lever to lower the rear lift it does not go down. I even moved the draft control and it doesn t move. This is with a bush hog cutter attached to the rear 3 point hitch. I would think with the weight of the cutter it should at least go down but I m getting nothing. What gives??
caterpillar guy
02-13-2020 00:38:22
 Re: 574 Hyd. Lift will not go Down in reply to RTR, 02-11-2020 21:39:21
Move the draft control lever to the lower end of it's travel. You will see a rabbit for fast and turtle for slow. Then your lift lever should let it drop. The draft lever will adjust the drop speed. Also is the remote lever in a position other than Neutral. It is easy to catch that with your foot or leg getting on and off the tractor. IF this does not help. When was the filter last changed. It is on the left side under the foot platform in that cover that has a bolt in the center peak. You will get about a gallon or 2 of oil while changing it so keep the pail there.
Paul swPa
02-11-2020 21:55:08
I would think could be couple things. Linkage came apart (inside/outside- does the tube move with the lever?), or stuck drop poppet/valve or spring problem. Does it drop with engine off? If so pump is keeping lift side pressurized for some reason. Paul
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
