Company Logo Shop Now
IH 464 Hydraulics
Paul swPa
02-11-2020 13:33:48
I'm trying to get the unloading valve piston out of the unloading and flow control housing. This is the block on top of the rear housing, under the seat. Anyone have ideas of how to get it out, am I missing something? Will try to get a picture to load if it does it is part number 3 on the diagram. Thanks Paul Can't get the picture to load. Will try a little later.
jimb2
02-11-2020 18:07:12
 Re: IH 464 Hydraulics in reply to Paul swPa, 02-11-2020 13:33:48
Hi Paul, I don't know if this will work but sometime ago on this web site an old IH Mechanic suggesting loosening the big plug 2 or 3 turn and then start the engine and dead head the remote hydraulic valve and it may loosen the unloading valve. BE CAREFUL not to loosen the plug too much that it will blowout with the hydraulic pressure, just run tractor at idle.
Paul swPa
02-11-2020 21:44:22
 Re: IH 464 Hydraulics in reply to jimb2, 02-11-2020 18:07:12
Thanks jimb2. I have everything off the tractor right now, but if it comes to that I'll have to put it back on. Was thinking of trying the air compressor. Paul
Paul swPa
02-11-2020 16:34:36
See if I can get the picture loaded now.
Paul swPa
02-18-2020 14:34:54
 Re: IH 464 Hydraulics in reply to Paul swPa, 02-11-2020 16:34:36
Thought I would give an update on the 464 hydraulics. Took the block with the piston in to a long time local mechanic, he got it out with needle nose vise grips, came right out. Got some other valves out of the block for inspection, looked ok. When we were putting back together noticed that whoever had it apart before had the unloading valve piston (part #3 in the diagram) in backwards, that's where the problem seems to have been as I put back together today and ran tractor some with no more dead heading of the hydraulics. Paul
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
