Ellis Kinney
I have a standard Farmall M that needs new brake bands and also needs seals on the brake shafts. As most of you know from previous posts I am not a mechanic.
But I have successfully completed several projects recently. I have no idea about replacing seals. Does the deck need to come off and do I need to take the
transmission apart? Do the brake shafts just slide out? Depending on the transmission work, I may or may not attempt to do this. This tractor also has an M
& W hand clutch which complicates things somewhat. Thanks, Ellis
