I have an 856 Custom with the diesel engine. It is my primary snow blowing machine. I went out this morning to remove some drifts from the driveway and the tractor will fire and then die. Crank and it will
fire and die. I went to the University of Google for information and found that I could determine if the retaining clip has disintegrated by loosening the cover on the side of the pump until fuel leaks out.
Start the tractor and if it runs fine while fuel is leaking out, but dies when closed off then it is a good sign that the retaining clip has started to come apart.
I have worked on gas engines a lot and some minor diesel work like replacing injectors on a truck and replacing glow plugs, but I have never removed an injector pump so I want some advice since I read horror
stories all over the web. It is a Roosa Master pump. I have found that you want to find TDC compression on #1 before removing the pump. I have a neat trick I was taught as to how to find TDC compression on a
gas engine that involves removing the spark plug and replacing it with a makeshift paper towel plug and then tapping the starter until the plug pops out and then you can turn it by hand after that. However,
I'm not sure how to do this on my 856 without pulling the valve cover. Is there any way to do this without pulling the valve cover?
Once TDC compression is found and it is time to remove the pump, should the shaft go with it? Sounds like there are different views on this. What is the consensus here? I will be taking the pump to a local
shop here to do the rebuild as I do not want to screw this up since we could still see a lot of snow before winter is over. What do I need to know about the timing on the pump? Do I wire the throttle wide
open? Can you assist me in a walk-through of what many say is a simple process but yet I read lots of horror stories about injection pump replacements gone bad. This form has always been great with advice
and I feel bad that I take and do not contribute, but please know that it is greatly appreciated.
