1946 BN IHC
To our grand mechanics who have over come IHC winter clutch difficulties.
When I start up our IHC Farmall BN the clutch, "throw out, disengage section" tends to stick causing the transmission to turn over, causing gear grind when shifting into gear from stopped position.
>>Come spring I will do a tear down since I do need to put in a new clutch plate any way and possibly elongate the clutch rod to allow for better adjustment of the foot peddle, [ the one I put in two years ago was not new at the time but was to get me through and running]
>> What type of "anti seize" would be best to use {if any} to avoid future sticking clutch in the winters to come?
>> I figure that cold and moisture is the possible problem; since we live in midwestern Ontario Canada.
Thank you for your thoughts and experience related recommendations.
Wm.
Wm.
