drain engine block
khouse6
i have the radiator off of international 140. just came to mind, perhaps i need to put it back on and install anti freeze, or drain the block. i do not know how to drain the block on 140, or do i need to ? hope that there is no damage done.
a b c etc is what i know , so no problem with them.
There should be a block drain on one side f the block but not sure exactly where it would be on a 140. Should look like a simple pipe plug or if your lucky some one put in one like on radiators which I do when I pull the block drain out
does it not have the wing nut that ihc uses on theses engines for the block drain located on left side of block?
