Farmall Super A belly mower
bt73000
01-08-2020 14:03:07
I see belly mowers for sale now and then and most are listed for Cubs. What model mower would have been used on an A or super A? L59 Woods listed for a Cub the same as one for a super A? Thanks
Ken Hansen
01-12-2020 06:32:07
 Re: Farmall Super A belly mower in reply to bt73000, 01-08-2020 14:03:07
Well as the "A" and my "BN" are powered by basically the same motor I'm not surprised that it handles the L306. Now if you are letting the grass get around a foot tall and it's nice and thick that would be another story!
brooktre
01-11-2020 12:27:51
If you google search "woods undermount mowers for vintage tractors" (without the quotes) you'll find a link for a pdf catalog of Wood's mowers that will fit an A or Super A. I was concerned that my A might struggle with a 72" L306, but it has been no problem.
tn terry t
01-10-2020 17:01:49
Quoting Removed, click Modern View to see They made a L59A-3 and a 59A-2 both were for the superA-140 series tractors
JoeVT
01-10-2020 16:48:57
And I appreciate Woods put L. H. On the bolt heads to remind me they are reverse thread. Saves a lot of cussing
JoeVT
01-10-2020 16:43:07
Agreed. The bolts on my L59 are left hand thread. I must of misunderstood the above threads.
Ken Hansen
01-10-2020 16:30:19
I believe what John M was saying is if you install the belt the right way you can get the deck to spin the correct direction to have them cut as designed! NOT that you could spin the blades the opposite direction and still cut!
And Like I said I don't think you can run blades opposite to the direction the deck was made to turn. If you try that I would think you would find the bolts on the spindle that hold the blades to loosen up in hard cutting.
JoeVT
01-10-2020 15:50:51
I respectfully differ that the blades don t matter. There is generally only one cutting edge on a mower blade. By reversing the direction you are using the blunt side of the blade.
MtMan
01-08-2020 20:09:54
I have a Woods L59 mower on my Super A and love it. The way and the material it will cut, you would think it is a brush hog. The only problem I ever have is keeping the belt tighter than you would think it should be. If you ever have to replace the belt it has, I believe 2 turns in it and if you don't get them in the correct location it won't work. Great set up for me.
Ken Hansen
01-08-2020 16:54:46
I'm in no way an expert but have had a L306 on a Farmall BN for a few decades.
One thing I would say about trying to reverse the direction of of the mower deck is the bolt that hold the blades on the L306 are left hand threaded. If on was to reverse the way the blades ran you could have a problem keeping the bolts tight.
So if deck is designed for right hand rotation do what you need with the belt to keep it rotating that way!
Just my opinion and it's worth just what it cost you!
Charlie M
01-08-2020 15:26:39
The PTO on a Cub rotates opposite from an A so you would have to have a way to change the rotation of the mower.
gene bender
01-08-2020 16:14:53
 Re: Farmall Super A belly mower in reply to Charlie M, 01-08-2020 15:26:39
the rotation of the blades starts with how the belt is placed on which side of the center spindle that determines which way the blades will turn. the twists will be the same on both rotations. The decks are either right or left throw
JoeVT
01-08-2020 14:40:03
iirc The L is for left discharge and was for A s. The 59 is right discharge and for the cub.
I ve been told you can twist the belt on an L59 but you would need to get blades for a 59 for it to cut
gene bender
01-08-2020 16:23:20
 Re: Farmall Super A belly mower in reply to JoeVT, 01-08-2020 14:40:03
The deck is either right or left which ever you buy tractor makes no difference. I have sold and installed those mowers new an used. Blades are either right or left and so are the threads on the spindles so the blades do not come loose during use. Sometimes when replacing belt it gets wound wrong and the mower just does not mow very good
John M
01-08-2020 15:36:11
Wouldnt need blades. By twisting the belt your making the mower turn the right direction, or wrong direction, or you know.
gene bender
01-08-2020 14:26:42
The decks are all the same it is the mounting brackets and the drive pulleys that are different
