F Series Light Switch Details
mn-mike
New User
Hello everybody. I'm working off third hand information to help out a coworker of a friend. Hopefully the image uploaded correctly to help give some context.
In the picture is what I believe to be the light switch for an F series tractor. My friend was asked to 3D print a copy of the switch lever, so that his coworker can mold it and cast a new one. All we have to go on is the attached picture.
Can any of you confirm this is actually a light switch for an F series tractor? I have asked my friend to confirm this with his coworker, but I have not heard back yet.
If anybody has one or has literature about it, could you send me the detailed dimensions to send to him?
Any help would be greatly appreciated. Thank you very much!
i do not know what kind of a sw that is but its not from a F series lite sw. To find one look at Farmall Parts on ebay and there will be some. You will nee a dia for wiring one. What kind of a tractor do you need one for
That appears to be an F-series switch, an F-12 or F-14 or F-20, etc. Good luck finding out anything about them. I've never had reason to try but I'm guessing it may be tough.
CC
I will say that is not a light switch from F series Farmall.
Rustic red acres sells an aftermarket copy of an F series light switch box
that matches pictures from old Heisler light kit sold for Farmall F series.
Check out Dwyane Hanford's website see his light box.
That's switch may not be Factory
correct. However it is 'period correct.
It looks like something a farmer would
have put on when he added electric
lights to his F series tractor. In any
case it would be a fine addition to your
old tractor.
I may be on the wrong track here, but that switch and case look like:
3657 D lighting switch case
and
13098 D lighting switch (single fuse)
or
27398 DA lighting switch (double fuse)
These are for Bosch no battery lighting. Listed in F12 / F14 parts book on pages 239 and 240.
SadFarmall
A coupe of photographs
Bosch no battery parts
No Bosch or correct Delco-Remy parts available here in Australia, so I used a Lucas plc switch
Thanks - I was hoping someone out there had a pic of it. My parts book is somewhat damaged, so the housing pic wasnt
that great, so I couldnt tell if the housing was right or not.
