350D pushrod
Finally got the 350D valve cover off today.
Might be a problem that there was no pushrod on
#4 exhaust. This unit has been down for several
years pending enough time to investigate.
Can't find engine parts---Harvester doesn't even
list the 350D on their site.
Does anyone have a source for these pushrods?
Thanks for any help.
Jim
(quoted from post at 17:46:08 12/24/19) Finally got the 350D valve cover off today.
Jim
The IH parts site lists both the IH and Farmall versions of the 350, and diesel engine parts are listed in the "engine" sections of both.
Intake and exhaust pushrods apparently are the same, 367330R1, nla from FIAT, a GOOGLE search will shoe some places to check with for a used one.
I bought a parts tractor a while back with engine torn down I think the pushrods were there if you are interested in a used one. Let me know, Mike
I worked on one a few years ago. Bates had everything I needed. Push rods,cam gear, lifters etc. the one I worked on ate the cam gear, had four bent push rods with an extra one at the bottom of the oil pan. Was also missing middle cam bearing. Very expensive engine to work on.
Hey, Mike
Much obliged for the offer on the pushrod.
Could probably use 2 if you can spare them.
Am going to see what the others look like when I
get them out. Hope the cam didn't get nicked when
the pushrod went ker-flooey.
Thanks to all the others for their help.
Jim
Hello Jim, pushrods look good to me. Cam looks good also if you find bigger problems. Email me your address, pushrods should be easy to mail. Merry Christmas
Hi, Mike
I sent you an e-mail on the 26th with
our e-mail address, but never got a reply.
I'll try to send again & see if it goes through.
Jim
Hi, Mike.
The e-mails aren't getting through
for some reason. Get ahold of me
at 563-732-2420. Best around 7:00
AM Iowa time.
Jim
Have been away from computer for a couple days, see your email with your address. I will get those pushrods headed your way on Monday.
