560 Injector Lines Stuck....
Absent Minded Farmer
I have the big fittings on the lines free, but the line itself still turns with the fitting. I am holding the injectors themselves with a wrench & they are not turning. Tried tapping on the lines & it makes no difference. Tried penetrating oil & no deal. Any ideas?
Thanks,
Mike
The only things I can think of is try going back and forth with the 3/4 wrench rapidly , try tapping on line the same time your doing that, maybe try kinda tapping nut/line into each other, and if all that fails try a vice grip on line while you work it.
Yep, tapping on the lines, with a vice-grip to hold the line in place worked. They were still binding, so I used the other penetrating oil. Mouse milk. Should have used that in the first place. Say, are you set up to test injectors also? I may just send them along if you are. The engine has low hours on it, but I'm interested in seeing if they are still atomizing properly.
Mike
I can clean and test the injectors, but if it were mine I'd leave them alone. I only pull those injectors if I KNOW there's a problem with them. Early type have no parts available, and late type are over 100 bucks apiece for the valves. They don't have much of a spray pattern being one hole anyway, mainly have to hold pressure.
I have to pull the injectors & glow plugs anyhow to replace the o-rings for the pre cups. Also, the tractor is getting a rebuild to be my main horse for next year & would rather not cut corners if I can help it.
Mike
While the head is apart, have it machined for all new valve seat to get the valves flush with the flat head surface. If the valves and seats are just ground, all valves will be sunk too low which WILL LOWER the compression and cause harder than normal starting/rough cold running.
I've never broken any injector ears prying them out, some looked like they had been in a war though. If both upper and lower pre cup gaskets were sealing correctly injector and cup will slide right out. If the head bore has carbon buildup use a brake cylinder hone to clean the bore. The injector O ring is for dust only, it won't hold compression, that's what the cup gaskets are for.
