Seating for 2 on a Cub ?
Anybody ever see or have a side-by-seat solution for a Cub? I need a butt buggy and am entertaining something like this. Might consider an A too. Not interested in a B because of the width.
Thanx !
Have not seen any side by side seats on Cubs or As, tractor is too narrow to do it safely, have seen lots of Bs, BNs and some Cs, may want to check out the BNs, wider than an A, but not as wide as a B.
I could see it on an A but the person on the left side would have leg problems since there no place for there legs unless there facing backwards and then you do not want to use the PTO in any way
not hard to have two seats on a Cub. Left seat right over the wheel and steps to get there with hand rail and backrest that would be for both seats. Platform for feet also.
Hi,have seen a decent amount on offset/cultivision tractors with a bench seat,and a some of them have a milk crate or something,somebody put next to the original seat,but there is definetly plenty off space on one of these to work with,rock
It's not side by side but real close, I bolted a pipe frame seal from an old H-M to the drawbar of my CUB and it worked great. When the seat was placed at an angle the bolt holes even lined up.
There is one company that makes a double wide seat, but I can't recommend dealing with that company, so I won't mention their name.
Regardless, there is no ready-made solution out there. Even that double wide seat is only the seat. You'll have to come up with some sort of base on your own, as just bolting it to the stock Cub seat post is not going to be adequate for even two light people.
I know/known a few people that if they sat on there seat the front end would be likely to be to light . LOL
I converted a Super AV to a Buddy Seat tractor by adding BN axles and housings to both sides. I then added a BN drawbar assembly, left side platform, seat, steering wheel & shaft and pedals. It works great and gets a lot of looks. It's been over the Mackinaw Bridge 4 times so far!
