1974vette
Working on a wr9 with a hand clutch. I bought a new clutch disc over a year ago from a old IH dealer. When i pulled it from the shelf to use
it the spline is too small. I am looking for ideas where to start looking for a new or good used disc. My next thought would be to get the
disc i have relined if that is possible. Any ideas and suggestions would be appreciated thanks in advance.
If it is correct in all other ways, and similar in construction, the old spline hub might be able to be put into the new disk. It is very possible to find a spline and diameter that match, but not the part number. Relining it is a matter of finding a competent drive line company. Jim
I am afraid if i remove the spline portion of the disc and cant get them exactly centered then i have 2 pieces of junk.
If u know of a good place to get it relined i would go that direction?
Give these guys a call. I have used their components and found them to be superior. They are at least going to give you reliable information. If you know the spline size, offsets, thickness, and diameter accurately, they will probably find the part jim
it should be possible to remove the spline hub from the new disc you have and use the old spline hub on it. I have gotten clutch discs relined on my 560's and 660's.thing is to find a clutch and brake shop. did mine in Edmonton Ab.
I have one out of a WD9 hand clutch tractor that looks like new I would sell
