Goose
Earlier this fall, I bought a 1944 H to go along with my other two H's and my M.
Since there was no panel mounted fuse on the ammeter box, and the ammeter never showed over a couple amps charge, I assumed it still had the original style generator with a cutout relay.
Even though the rest of the tractor is healthy, the insulation on the wiring was bad to a point of falling off and leaving bare wires so I decided to rewire it. I also decided I may as well upgrade it to a voltage regulator and went ahead and bought a new regulator. (From YT).
Anyway, when I dug into it, I found it already has a late style generator with the third brush fixed instead of being adjustable, plus it had a regulator instead of a relay. One wire by the regulator was unused. It still had the old style light switch with a fuse on it inside the ammeter box. The wiring was such a mess it was impossible to trace it out visually.
Yesterday, I simply pulled all of the old wiring off, including the light wiring, and ordered a new style light switch and panel mount fuse. Armed with the proper wiring diagrams and plenty of experience with wiring, including jet fighter planes, my objective is to build a whole new wiring harness from scratch appropriate for the new style system with a voltage regulator. I'll have to rework the ammeter/light switch panel a bit to accept the panel mount fuse. Have I overlooked anything?
BTW, having worked in Avionics and wiring in jet fighter planes where there are EXTREMELY rigid quality issues involved, I've been appalled over the years at some of the cobbled up messes I've run into for wiring on vehicles and tractors. I rewired another H earlier this year and greatly simplified a mess someone else had made.
