Long story short, just redone my grandfathers 140 which sat
for probably 20yrs. Rebuild motor, new clutch, painted,
changed all fluids, tires etc. I have a noise in the trans that
almost sounds like a bearing, almost sounds like a rod knock
if that makes sense. The noise goes away when the clutch is
pressed, going down hill etc but gets worse when under any
load or going up hill. There was some water in the trans and
some rust on gears but everything turns free and smooth by
hand. I?ve drove it around the yard several times and flushed
with kerosene twice and oil twice not much difference. PTO is
not engaged and it doesn?t get worse when it?s engaged. Any
help is appreciated!
