Early Farmall A decal placement
isaacjr75
Hello! Does anyone have diagrams or even pictures of where the assortment of decals go on these tractors? I generally know some of them but if anyone could share exactly where they go I would appreciate it!
Thanks!
Some of what you have were not used and where is the Cultivision A. looks like you did not get them from a good decal place or some of them would no be there and you are missing some. Get your set from MAPLE HUNTER theirs are some of the best on the market.
The set [u:9e421db57e]IS[/u:9e421db57e] from Maple Hunter...there are a couple others in the picture, but the die cut ones are from there...
I've got an originality guide but it doesn't say much about an A, has more about a Super A.
I would think most of the safety type decals would be in the same spot if you have that?
(quoted from post at 15:19:30 12/17/19) I've got an originality guide but it doesn't say much about an A, has more about a Super A.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto134.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto135.jpg">
Best as I can decipher
trade mark decal midway between rear of hood and where hood bead starts to turn up, decal to lay at top of bead.
model symbol A is 1/2 inch from bead radius
oil filt. decal one inch above base.
oil breather decal just above cap bead.
drawbar warning centered two inches below top seat lip.
light switch decal pictured in factory drawing between 9 and 12 o'clock, photo in book suggests centered in 9 o'clock position might be more accurate.
air cleaner decal 3 inches from top of canister body.
coolant drain11/16from bottom of block left side and 3 inches from frt. of block.
pto decal 19inches ahead of rear of gas tank
brake pedal operation 1/2 inch in frt of pto decal.
Weather you got the right decals I don't know, there always seems to be a couple of extras or a couple missing.
