Moranmillfarm
New User
1975 IH 1066, working fine, pulling fine. Then clutch cylinder badly leaking hydraulic fluid. Had mechanic who talked IH talk, replace seals and o rings in clutch master cylinder. Drained (all 5 drain plugs) and changed hydraulic fluid, including filter. Added 25 gallons. Clutch no longer works. Worked barely enough to get it out of building but will not move forward or reverse now. Mechanic says fix clutch. Clutch was working with no issues. Former owner said slave cylinder adjustment. Can't find any info. Please any ideas ? Hate to split tractor to replace something that was working and still should be.
