Doug Kieta
I just bought a Denso 1-Wire Mini Alternator and want to convert my 1949 SA from a 6 Volt positive ground system to a 12 Volt negative ground system. In order to accomplish this I need a wiring diagram for the 12V setup. Anyone have one. The 6V system is a magneto ignition system with the battery servicing the starter and lights. The generator has a cutout relay mounted on top if that adds to the clarity of the conversion wiring. Also, does it matter if the lead to the starter is from the positive terminal of the battery rather than the negative terminal as currently wired?
Thanks for the help.
