Hello! My students and I (high school Ag teacher) are working on restoring a 1941 Farmall A (great story about this tractor I will show and tell in another post). When we received the tractor the magneto was damaged and the ignition system was poorly rigged, so we are starting basically from scratch to wire it. We are converting it to a 12 volt alternator system with an electronic ignition distributor. While we have the basic diagram included with the kit, I am looking for pictures of examples of how some have wired this type of set-up. I have a new complete restoration quality wiring harness that we'd like to use if possible (even if it needs to be slightly modified). Looking at different examples online, I see there are a ton on "pull" or "push" type set ups. I'd like to incorporate the On-off original switch, a solenoid and a key switch if possible. If you have any examples you could share, that would be greatly appreciated!
