1953 Super C
trailryder
New User
Can anyone tell me if all 1953 Super C's had a water pump. I have one that don't. I have verified that it is a 1953. Someone has put a shorter radiator from a C on it (which I am replacing with the right one). I'm thinking when the radiator was changed they also took the water pump off and used the bottom radiator hose hookup from a C.
Super C had water pump. sounds like you have a 'mutt'. A lot can get changed in almost seventy years.
I am going to say this because, when I bought my Super C I did not know the water pump is on the left side of the engine, not in the center where you would expect it. The lower hose goes to the water pump.
How's the sheet metal fit if it's got a short radiator? Is there a two inch gap under the gas tank, curved pedals or straight?
Mine has the wider gap under the tank. The top of the grill had been mashed down so that the radiator cap could be accessed. My son has a C and I have compared the differences. I think when the radiator was changed the water pump was replaced with the lower hose hookup from a tractor without a water pump. I am going to replace the radiator with the correct one and install a water pump.
Sure is a super C. I want to add a small plow likes yours to my SC. Can you take a few more pictures especially of the front. Does the chain lift blade very high? Beautiful SC.
