cub bearing numbers
boler76
the rod bearings that are in my cub are IH #251248 R2 but I am having difficulty decifering if the new rings listed on this site with different end numbers are the same? Thanks
I take it that the bearings that are in it now are correct and my problem is I cant seem to perfectly match the existing rod #s with new listed rod #s I do have the rod # and it is 251246R1 Thanks
I seem to have been writing rings when actually I am trying to get replacement bearings, Vintage is my problem and it isnt the Cubs vintage I am talking about
If you are talking about the number after the "R," that is the revision number.
When the number after the R on the new part is higher than the number on the old part, that just means it's a newer revision and in nearly all cases, 100% compatible with the old part.
