Need source for square headed bolts
Paul Shuler
04-14-2001 20:19:58
I need a source for the square headed bolts that hold on the rear wheel weights. Thanks
tiny
04-15-2001 17:51:17
 Re: need source for square headed bolts in reply to Paul Shuler, 04-14-2001 20:19:58
try the john deere dealer i found some there that were not a bad price seams like 20 dollors got me enough to put the rear tires on my "A"
The Undertaker
04-15-2001 17:16:17
Paul:
Case/IH dealer in Burlington, NC advised the only square heads are what Case/IH dealers might have left in their bins from years ago, but they no longer stock them. Check the web pages for "Fasteners" as I had need of the same some months ago. A neighbor provided me with some oldies, but I did find a company that manufacturers them and forget who they were?
The Undetaker
Roger
04-15-2001 14:16:54
Paul,
You can also get them from McMaster-Carr in Chicago by mail order. They have a good selection of all sizes. The smaller ones you have to order a box, but large sizes can be ordered by the bolt. Their web address is www.mcmaster.com. I replaced the 5/8" bolts that hold the rims on on my MD and they were about $1.40 each. Roger
The Red
04-16-2001 15:04:48
 Re: Re: need source for square headed bolts in reply to Roger, 04-15-2001 14:16:54
Roger I was on their site but couldn't find the square heads. Could you tag the page and post it for us? Thanks in advance!!
Roger
04-16-2001 20:08:42
 Re: Re: Re: need source for square headed bolts in reply to The Red, 04-16-2001 15:04:48
The square head bolts are on page 2852. You can get to it by going to the contents page which is the opening page when you go to the web site. Then look down to "Fastening and Sealing". Then go "Cap screws & bolts". Then Bolts, and finally "square head". You can see the actual catalog page also. Hope that helps. Roger
Dave BN
04-15-2001 06:20:30
Paul; I bought new bolts for my rear wheels on my BN. Got them at Case/IH dealer. He had to order them and they were expensive. Eight 5/8 x 2 1/4
bolts,nuts,washers and lock washers cost about $38. This was the only source I found for grade 5 square head bolts where I didn't have to buy a large quantity. Dave BN.
kimk
04-15-2001 06:02:29
Bought some off the shelf from our local industrial supply house, R.I. Baker (Ribco) in Clarksburg Ma. Don't remember the price but I thought they wern't bad.
Tom H
04-14-2001 20:43:22
I stock a 3/4x5 1/2 and a 3/4x6 both grade 5. How many you looking for
Tom
Illinois Red
04-14-2001 20:34:52
I don't know if Case IH offers them or not, but I know that JD does. They still use them to put weights on with.
5/8 vs 3/4
04-15-2001 08:40:42
 Re: Re: need source for square headed bolts in reply to Illinois Red, 04-14-2001 20:34:52
Farmall uses a 3/4 as JD uses a 5/8 diameter bolt
Haas
04-15-2001 05:33:51
You can buy them at IH, but the price is high! I ended up using Hex head bolts. Too cheap to pay the IH price.
Dave T
04-15-2001 09:54:30
 Re: Re: Re: need source for square headed bolts in reply to Haas, 04-15-2001 05:33:51
..... ..and then you can chuck them up in a lathe and face off .010 or so, and leave the center spot in the middle. Now you have an old fashioned square nut....Dave
