574 ignition part
Mike Van
A few days ago my 574 gas engine wouldn't turn off with the switch - Looking aroound under the hood for a problem, I found whats called a diode, hot enough to melt the plastic on it. Pulling the connector apart, tractor shut off. Where to find the part # for this diode?
(quoted from post at 13:23:36 12/10/19) A few days ago my 574 gas engine wouldn't turn off with the switch - Looking aroound under the hood for a problem, I found whats called a diode, hot enough to melt the plastic on it. Pulling the connector apart, tractor shut off. Where to find the part # for this diode?
Sounds like it's an alternator conversion using a diode in the alternator "excite" circuit.
I use 1N5408 diodes for this purpose, their voltage and current ratings are "overkill" for this use, yet they are CHEAP.
If you GOOGLE the # you will find an almost unlimited amount of sources.
One seller has them 10 for $1.89 on ebay!
Others on here will argue to use a much less current and voltage rated diode, yet they will not be anymore than a few pennies cheaper, at the most.
Once you get a new diode, note the while band at one end (cathode).
That end gets wired to the alternator's #1 (excite) terminal.
1N4004 (also 4005, 4006, 4007, etc) work too.
Last 1N4004 I purchased was 29 cents(!)
