Hotflashjr
- Location
- Western MA
Is it common for the shifter on late 40's cub's to break where the roll pin holds the spring onto the lever? Mine the other day popped right off in my hand. You could see it had been cracked and weak for some time.
Looking for a used/new replacement there seems to be some differing info out there. Difference seems to come down to pan seat vs deluxe seat. Mine has a pan seat so I need a straight lever. However can a used straight lever shifter from say a late 50's early 60's yellow cub be used on a late 40's cub?
Thanks.
Thanks.
