Company Logo Shop Now
TractorLinks.com
Order Farmall Cub Parts Online
cub drawbar
cheif
12-01-2019 08:51:47
When I attach my grader blade I lose my rear drawbar which I need too. What is the solution to this? I would like to hear from some cub owners. As always thank's for your comments
ajhbike
12-03-2019 05:29:54
 Re: cub drawbar in reply to cheif, 12-01-2019 08:51:47
I made a substitute drawbar out of some heavy flat stock per the farmallcub.com prints and it works well
tn terry t
12-02-2019 10:49:39
john is 100% right if you mount the drawbar in the forward holes its up almost against the front tires ya cant angle the blade I had forgot about that until john jogged my memory
BarnyardEngineering
12-02-2019 05:21:24
One common solution is to buy another Cub.
john *.?-!.* cub owner
12-01-2019 20:37:36
Turned forward, but not floated, typed it wrong.
12-01-2019 20:36:26
To use the blade belly mounted, the drawbar uses the rear mounts, just turned forward and floated. the farmallcub dot com forum has dimensions for the substitute drawbar you can see once you have made a post or two.
antiqueIH
12-01-2019 10:20:01
I assume you are placing the blade in the mid-mount position where you have to turn the drawbar forward in order to mount the blade. If so, the easiest thing to do is buy another drawbar and bolt it on in the normal position. Trust me, it will bolt right up.
tn terry t
12-01-2019 09:09:04
they made a "substitute drawbar" for just this its a little flimsy looking to me but its factory
tn terry t
12-01-2019 09:04:49
Quoting Removed, click Modern View to see they made a substitute draw bar for just this purpose looks a little flimsy to me but it was factory http://www.external_link/tm-tractor/gdr/subdrbar2_001.htm
cheif
12-02-2019 07:16:08
 Re: cub drawbar in reply to tn terry t, 12-01-2019 09:04:49
Thanks guys. I already have a couple more cubs, just like to make things a little more convenient. for me they are just toys but I enjoy tinkering with them.
Copyright © 1997-2020 Yesterday's Tractor Co.
