I'm going to rewire a 42 H I got from my wife's uncle a few years ago. Couple questions:
1. Should the F generator terminal be connected to the F regulator terminal? Now it's just tucked between the regulator and the generator. It still has 6V system, no headlights so no light switch with the ammeter. Suspect originally had a mag but now has a coil and distributor.
2. There doesn't appear to be a fuse anywhere in the wiring. Shouldn't there be? If so, where should I put it and what amp fuse?
