Dave H (MI)
Been asking about this off and on the past month. I will have to do it in the Spring but I want to get my head around exactly WHAT I will be doing now. I have saved the prior threads so that I have a reference to work from. Never having had this apart before, I am not 100% sure how it all works. I had removed the distributor cap and there was oil inside it. In prior posts we talked about a seal that may or may not have scored the distributor where it passes thru the seal.
Here is a picture of my distributor and hydraulic pump. Can someone give me an idea where the seal/gasket is that I am going to be replacing? I see a couple possible places. About even with the bottom of the coil is where the distributor bolts to the pump. Or on the other side of the pump. Whereabouts is it?
