Company Logo Shop Now
IH history re: B C
ckain(mi)
11-29-2019 17:03:29
Anyone have the information re: years of manufacturer of the IH 'B', 'C' & 'superC' ... we thank you.
D Slater
12-04-2019 16:09:13
 Re: IH history re: B C in reply to ckain(mi), 11-29-2019 17:03:29
As a note, at a red power round up in Wisconsin a room with persons to answer questions about IH records or other questions was setup. Didn't get to talk to Guy Fay but after questioning another rep he admitted it needed looked into about the 53 starting serial number for most or maybe all except one rock island SM. Don't know if I helped or confused things. Thanks
D Slater
12-04-2019 08:55:46
May want to check out the start of 53 SM at Rock Island. Serial 12516 was maybe a diesel SM of some type as the first completed in 53. Best I can figure out 12919 was the first SMD that maybe didn't get completed until 53. But the rest of SM that were not diesel started at serial number 21074 according to IH records. Quite a difference in starting numbers when the highest percent are looking up non diesel SM. For some reason SMD builds stalled at the end of 52 and by first built in 2- 1953 had jumped to serial 27711. IH records show SMD 12919 being the first built from 9-52 to 1-53. Whatever is correct have looked at enough 53 non diesel tractors to know starting number was higher than 12516. Also enough 52 to know they were built later than 12516.
PeterE
12-04-2019 13:49:24
 Re: IH history re: B C in reply to D Slater, 12-04-2019 08:55:46
Thanks. Both Guy Fay's Farmall Letter Series book and Robert Pripp's Farmall Tractors book used those serial number charts, but they don't match what shows up in the records from the historical society.
D Slater
12-04-2019 05:05:58
Just as I wouldn't claim to be correct every time, also wouldn't claim tractor data is every time. One of some I remember from tractor data is a 54 Louisville SM listed when they stopped in 53. Shows some tractors negative ground when they were positive. Could keep going but what's the use.
PeterE
12-04-2019 07:10:25
 Re: IH history re: B C in reply to D Slater, 12-04-2019 05:05:58
Not "they" is me. Just me.
You are correct, the last Louisville serial number should be labeled as a final number, not of the start of '54. I'll get it fixed tonight when I got home from work.
BarnyardEngineering
12-03-2019 05:06:12
I never said it was worthless, I said it wasn't always 100% correct. BIG difference.
There are literally THOUSANDS of tractors listed on that site. A few years ago it was horrible. Farmall 756 being listed as a ~100HP tractor, for example. That was several years ago. It's much better now, but past performance has sown the seeds of doubt. Trust but verify.
Ken Hansen
11-30-2019 08:39:33
I know I had a typo on that test date but no editing so it will have to stay!
Ken Hansen
11-30-2019 08:38:17
Well the 0.04 difference in HP between the A and B in the 1934 test could be just caused by how each one was broke in or manufacturing tolerances. Or even if two different dynometers were used or air temps on days of testing!
BarnyardEngineering
11-30-2019 07:36:03
Take tractordata information with a grain of salt. It's not always 100% correct. If you want real data look up the Nebraska Tests for the individual tractors.
B and BN are considered the same tractor.
A and B/BN were manufactured until 1947, when the Super A and C were introduced to replace them.
DR. EVIL
12-02-2019 12:37:45
 Re: IH history re: B C in reply to BarnyardEngineering, 11-30-2019 07:36:03
There's direct links on the "Tests" page on EVERY tractor on TractorData, and on every fuel variation. The hp listed on the main page on TractorData is in every situation the same numbers I've seen on the Ndbraska test results.
I've heard this "Melarke" about "TractorData is Wrong, it's worthless" since the first day I came back to this forum after leaving for ten years. There's a LOT of wrong information on this website but it's nothing to do with TractorData!
Ken Hansen
11-30-2019 06:24:41
Interesting in the HP ratings that the A shows 17 horse and the B shows 20 horse. I was under the impression they were the same engine??
Also wonder why the BN is not listed or is it just considered a sub-group of the B?
Ken in NY
PeterE
12-02-2019 08:06:18
 Re: IH history re: B C in reply to Ken Hansen, 11-30-2019 06:24:41
The BN is available by the link on the B's page (under variants).
The difference is due to how the software is calculating HP for the overview page. It's taking the advertised PTO figure for the A, versus the tested belt figure for the B.
D Slater
11-30-2019 07:07:31
A and B gasoline 1939 Nebraska tractor tests show A 16.86 HP. B 16.82 HP. C 19.91 HP, SC 22.92 HP.
gene bender
12-01-2019 06:33:34
 Re: IH history re: B C in reply to D Slater, 11-30-2019 07:07:31
wasn't any C or SC in 39
D Slater
12-01-2019 17:20:27
 Re: IH history re: B C in reply to gene bender, 12-01-2019 06:33:34
If my post is the one in question I didn't post very well. A and B tested in 39 and I failed to put dates on the others.
khouse6
11-29-2019 17:36:11
http://www.tractordata.com/farm-tractors/tractor-brands/farmall/farmall-tractors.html
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
